当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Locate the base of the motherboard.
Slide the Plastic Opening Tool along the base of the motherboard to separate it from the phone.
Gently guide the two pieces apart with upward motion.
Caution: Do not damage the ribbon that is holding both pieces
Flip the mother board over.
Locate the base of the ribbon cable.
Pull straight outward using the Plastic Opening Tool.
Disconnect the ribbon cable connecting the display to the logic board
Pull the two halves of the device apart to disconnect the second (wider) ribbon connector.
Note: The ribbon connector is bonded to the logic board with adhesive, simply pull it to remove it completely.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
