跳转到主内容
配件
没有特定配件。
  1. Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Insert the opening tool between the battery and the battery holder and wedge the battery out.
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
结论
2等其他人完成本指南。
Dorian Capps
于2013年04月19日注册
64 信誉积分
创作了2篇指南
团队
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G22
3 名成员
创作了4篇指南
一条评论
There isn't really much need for guidance on replacing the battery, but it would be helpful if you could provide some details on how long it takes for the first charge after replacement. I connected my charger after replacing the battery and it only lights up the back/menu/home keys below the screen - no indication of battery charging etc. and the phone cannot be powered yet. It's been charging for well over half an hour. Any advice?
shaunschon - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,506
