跳转到主内容
Motorola Defy Earpiece Speaker Replacement
你所需要的
  1. Motorola Defy Earpiece Speaker Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Earpiece Speaker Replacement: 步骤 2 中的图像 1,2 Motorola Defy Earpiece Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Earpiece Speaker Replacement, Battery: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Earpiece Speaker Replacement, Midframe: 步骤 4 中的图像 1,1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Earpiece Speaker Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy Earpiece Speaker Replacement, Motherboard: 步骤 6 中的图像 1,2 Motorola Defy Earpiece Speaker Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Use metal spudger to pry off the middle yellow flap carefully.
  7. Motorola Defy Earpiece Speaker Replacement: 步骤 7 中的图像 1,3 Motorola Defy Earpiece Speaker Replacement: 步骤 7 中的图像 2,3 Motorola Defy Earpiece Speaker Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers again to pry off the second yellow flap carefully.
  8. Motorola Defy Earpiece Speaker Replacement: 步骤 8 中的图像 1,1
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
  9. Motorola Defy Earpiece Speaker Replacement, Remove the earpiece speaker: 步骤 9 中的图像 1,2 Motorola Defy Earpiece Speaker Replacement, Remove the earpiece speaker: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Once the motherboard is removed, use either the metal tweezers or the metal spudger to remove the speaker by prying it as shown.
    • The speaker is glued to its position, thus you will have to glue the new one back on.
    • The speaker must be pried off carefully. It is very delicate.
结论
Andres
于10/08/14注册
101 声望
撰写一个指南
团队
USF Tampa, Team 14-2, Leahy Fall 2014 USF Tampa, Team 14-2, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 648
