跳转到主内容
Motorola Defy Display Assembly Replacement
你所需要的
  1. Motorola Defy Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,2 Motorola Defy Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,2
    • Remove the battery cover and the battery itself.
  2. Motorola Defy Display Assembly Replacement: 步骤 2 中的图像 1,2 Motorola Defy Display Assembly Replacement: 步骤 2 中的图像 2,2
    • Using a Torx T5 screwdriver, remove both screws near the camera.
  3. Motorola Defy Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Using the Torx T5 screwdriver, remove all 7 screws around the mobile: 3 on each side + 1 on the botton.
  4. Motorola Defy Display Assembly Replacement: 步骤 4 中的图像 1,3 Motorola Defy Display Assembly Replacement: 步骤 4 中的图像 2,3 Motorola Defy Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Using a plastic opener tool, open the device removing the back cover.
    • Remove the power button and volume button.
  5. Motorola Defy Display Assembly Replacement: 步骤 5 中的图像 1,3 Motorola Defy Display Assembly Replacement: 步骤 5 中的图像 2,3 Motorola Defy Display Assembly Replacement: 步骤 5 中的图像 3,3
    • After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard.
  6. Motorola Defy Display Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove the two yellow rubber protectors near the screws. The rectangular yellow rubber protector might fall off too so put it aside.
  7. Motorola Defy Display Assembly Replacement: 步骤 7 中的图像 1,1
    • Separate the Frame + Digitizer, the LCD and the mainboard.
  8. Motorola Defy Display Assembly Replacement: 步骤 8 中的图像 1,3 Motorola Defy Display Assembly Replacement: 步骤 8 中的图像 2,3 Motorola Defy Display Assembly Replacement: 步骤 8 中的图像 3,3
    • Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help.
    • Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it.
    • Follow this backwards to reassemble the mobile.
结论
11等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 5,856
