跳转到主内容
Motorola DROID RAZR MAXX Camera Cover Replacement
你所需要的
  1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: 步骤 1 中的图像 1,2 Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: 步骤 1 中的图像 2,2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola DROID RAZR MAXX Camera Cover Replacement: 步骤 2 中的图像 1,2 Motorola DROID RAZR MAXX Camera Cover Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola DROID RAZR MAXX Camera Cover Replacement: 步骤 3 中的图像 1,3 Motorola DROID RAZR MAXX Camera Cover Replacement: 步骤 3 中的图像 2,3 Motorola DROID RAZR MAXX Camera Cover Replacement: 步骤 3 中的图像 3,3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola DROID RAZR MAXX Camera Cover Replacement: 步骤 4 中的图像 1,1
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
结论
另外一个人完成了本指南。
Govind
于10/08/14注册
130 声望
撰写一个指南
团队
USF Tampa, Team 14-6, Leahy Fall 2014 USF Tampa, Team 14-6, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 719
