跳转到主内容
Motorola California Mobile Phone Rear Casing Replacement
你所需要的
  1. Motorola California Mobile Phone Rear Casing Replacement, Rear Casing: 步骤 1 中的图像 1,1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Rear Casing Replacement: 步骤 2 中的图像 1,1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Rear Casing Replacement: 步骤 3 中的图像 1,1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the old rear casing away from the rest of the device.
  4. Motorola California Mobile Phone Rear Casing Replacement: 步骤 4 中的图像 1,1
    • Locate the four holes on the new rear casing.
    • Align the holes in the new rear casing with the clips attached the to front casing.
    • Simultaneously insert all four clips.
    • Push down firmly until you hear the clips click into place.
  5. Motorola California Mobile Phone Rear Casing Replacement: 步骤 5 中的图像 1,1
    • Find a thin and sturdy screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the new key pad guard to the rear casing.
    • Use the screwdriver to push the rods away from each other until they click into their locked position.
结论
Andrew Lam
于04/17/12注册
35 声望
创作了4篇指南
团队
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012 的会员
CPSU-REGAN-S12S9G46
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 978
