跳转到主内容
Motorola California Mobile Phone Motherboard Replacement
你所需要的
  1. Motorola California Mobile Phone Motherboard Replacement, Motorola California Mobile Phone Teardown: 步骤 1 中的图像 1,1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Motherboard Replacement: 步骤 2 中的图像 1,1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Motherboard Replacement: 步骤 3 中的图像 1,1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Motherboard Replacement: 步骤 4 中的图像 1,1
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  5. Motorola California Mobile Phone Motherboard Replacement: 步骤 5 中的图像 1,1
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  6. Motorola California Mobile Phone Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
  7. Motorola California Mobile Phone Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • With your new motherboard, hold the LCD side of the motherboard face down. Align the four clips on the front casing with the four notches on the motherboard.
    • While doing so, insert the LCD into the compartment in the front casing.
  8. Motorola California Mobile Phone Motherboard Replacement: 步骤 8 中的图像 1,1
    • Press firmly on the motherboard until it is snug inside the casing.
结论
另外一个人完成了本指南。
Andrew Lam
于04/17/12注册
35 声望
创作了4篇指南
团队
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012 的会员
CPSU-REGAN-S12S9G46
5 名成员
创作了8篇指南
一条评论
Nice, thanks.
Daniel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 2,838
