跳转到主内容
Motorola California Mobile Phone Antenna Replacement
你所需要的
  1. Motorola California Mobile Phone Antenna Replacement, Antenna: 步骤 1 中的图像 1,1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Antenna Replacement: 步骤 2 中的图像 1,1
    • Insert the Phillips 00 screwdriver into the holes that connect the key pad guard to the rear casing in the plastic rod.
    • The following step may require a substantial amount of force.
    • Use the screwdriver to push the rods towards each other until they click out of their locked positions.
  3. Motorola California Mobile Phone Antenna Replacement: 步骤 3 中的图像 1,1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Push the clips outward while simultaneously lifting the rear casing and keyguard away from the front casing.
  4. Motorola California Mobile Phone Antenna Replacement: 步骤 4 中的图像 1,1
    • Locate and unplug the black component of the current antenna from the motherboard.
    • Under the black component there should be a blue component.
    • Unscrew the blue component in order to free the antenna.
  5. Motorola California Mobile Phone Antenna Replacement: 步骤 5 中的图像 1,1
    • Slide the antenna out of the green tubing.
    • Slide the green tubing out of its hole.
  6. Motorola California Mobile Phone Antenna Replacement: 步骤 6 中的图像 1,1
    • Insert the new green tubing into the corresponding slot.
  7. Motorola California Mobile Phone Antenna Replacement: 步骤 7 中的图像 1,1
    • Insert the new antenna into the green tubing.
  8. Motorola California Mobile Phone Antenna Replacement: 步骤 8 中的图像 1,1
    • Screw the blue piece of the antenna into the threaded hole on the motherboard until it is tight.
  9. Motorola California Mobile Phone Antenna Replacement: 步骤 9 中的图像 1,1
    • Align the protruding wire on the black component with the corresponding hole on the motherboard.
    • Push the wire into the hole.
  10. Motorola California Mobile Phone Antenna Replacement: 步骤 10 中的图像 1,1
    • Reverse the instructions from Step 2 to re-install the keypad guard and rear casing onto the device.
  11. Motorola California Mobile Phone Antenna Replacement: 步骤 11 中的图像 1,1
    • Push down on the antenna guard until it clicks into place.
结论
Andrew Lam
于04/17/12注册
35 声望
创作了4篇指南
团队
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012 的会员
CPSU-REGAN-S12S9G46
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 1,833
