当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Use your finger to press the button and free the device rear case.
You may have to force it a bit more to free its bottom if you open it for the first time.
slide the black button to free the battery so you can grab it with your other hand.
You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
Remove the 4 T6 Torx screws
Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
Use a plastic spudger to unclip the mic.
取消:我没有完成这个指南。
与1其他贡献者
于07/06/13注册
6,975 声望
创作了19篇指南
徽章: 30
+ 27更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 16
总计 382
