跳转到主内容
Motorola C350 Logic Board Replacement
你所需要的
  1. Motorola C350 Logic Board Replacement, Rear case freeing: 步骤 1 中的图像 1,2 Motorola C350 Logic Board Replacement, Rear case freeing: 步骤 1 中的图像 2,2
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. Motorola C350 Logic Board Replacement, Removing battery: 步骤 2 中的图像 1,1
    • slide the black button to free the battery so you can grab it with your other hand.
  3. Motorola C350 Logic Board Replacement, Separating the front case: 步骤 3 中的图像 1,2 Motorola C350 Logic Board Replacement, Separating the front case: 步骤 3 中的图像 2,2
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Motorola C350 Logic Board Replacement, Logic Board: 步骤 4 中的图像 1,2 Motorola C350 Logic Board Replacement, Logic Board: 步骤 4 中的图像 2,2
    • Remove the 4 T6 Torx screws
  5. Motorola C350 Logic Board Replacement: 步骤 5 中的图像 1,2 Motorola C350 Logic Board Replacement: 步骤 5 中的图像 2,2
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  6. Motorola C350 Logic Board Replacement: 步骤 6 中的图像 1,1
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
结论
Vincent Monteil
于07/06/13注册
6,975 声望
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 497
