跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Use this guide to replace the front case on your Motorola C350.
  1. Use your finger to press the button and free the device rear case. You may have to force it a bit more to free its bottom if you open it for the first time.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  3. slide the black button to free the battery so you can grab it with your other hand.
    • slide the black button to free the battery so you can grab it with your other hand.
  4. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
结论
2等其他人完成本指南。
Vincent Monteil
于2013年07月06日注册
6,417 信誉积分
创作了19篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 226
