跳转到主内容
Motorola C290 Speaker Replacement
你所需要的
  1. Motorola C290 Speaker Replacement, Outside Case removal: 步骤 1 中的图像 1,3 Motorola C290 Speaker Replacement, Outside Case removal: 步骤 1 中的图像 2,3 Motorola C290 Speaker Replacement, Outside Case removal: 步骤 1 中的图像 3,3
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Motorola C290 Speaker Replacement, Removing the front casing: 步骤 2 中的图像 1,2 Motorola C290 Speaker Replacement, Removing the front casing: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Motorola C290 Speaker Replacement, Disconnect the motherboard: 步骤 3 中的图像 1,2 Motorola C290 Speaker Replacement, Disconnect the motherboard: 步骤 3 中的图像 2,2
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Motorola C290 Speaker Replacement, Removing the motherboard/screen: 步骤 4 中的图像 1,3 Motorola C290 Speaker Replacement, Removing the motherboard/screen: 步骤 4 中的图像 2,3 Motorola C290 Speaker Replacement, Removing the motherboard/screen: 步骤 4 中的图像 3,3
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
  5. Motorola C290 Speaker Replacement, Speaker Removal: 步骤 5 中的图像 1,3 Motorola C290 Speaker Replacement, Speaker Removal: 步骤 5 中的图像 2,3 Motorola C290 Speaker Replacement, Speaker Removal: 步骤 5 中的图像 3,3
    • Insert spudger underneath the speaker.
    • Gently break the sticky seal between the phone case and speaker.
    • Lift the speaker off the phone case.
    • Note: It will be necessary to destroy the seal to remove the speaker.
结论
Philip Ybarra
于04/15/10注册
27 声望
撰写一个指南
团队
Cal Poly, Team 24-28, Regan Spring 2010 Cal Poly, Team 24-28, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G28
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,166
