当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Flip open your Motorola C290.
Remove rubber stoppers located around main screen using a push pin.
This reveals four screws.
Use a Torx T6 Screwdriver to unscrew the four screws.
Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
Firmly pry the screen components from the frame with a twisting motion
You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
Completely remove screen components from frame.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
