跳转到主内容
Motorola C290 Logic Board Replacement
你所需要的
  1. Motorola C290 Logic Board Replacement, Battery: 步骤 1 中的图像 1,2 Motorola C290 Logic Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Logic Board Replacement: 步骤 2 中的图像 1,2 Motorola C290 Logic Board Replacement: 步骤 2 中的图像 2,2
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Logic Board Replacement, Antenna: 步骤 3 中的图像 1,3 Motorola C290 Logic Board Replacement, Antenna: 步骤 3 中的图像 2,3 Motorola C290 Logic Board Replacement, Antenna: 步骤 3 中的图像 3,3
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Logic Board Replacement: 步骤 4 中的图像 1,2 Motorola C290 Logic Board Replacement: 步骤 4 中的图像 2,2
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
  5. Motorola C290 Logic Board Replacement, Logic Board: 步骤 5 中的图像 1,3 Motorola C290 Logic Board Replacement, Logic Board: 步骤 5 中的图像 2,3 Motorola C290 Logic Board Replacement, Logic Board: 步骤 5 中的图像 3,3
    • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
    • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
    • Note: This will reveal a screw. Five screws should now be visible.
    • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
  6. Motorola C290 Logic Board Replacement: 步骤 6 中的图像 1,2 Motorola C290 Logic Board Replacement: 步骤 6 中的图像 2,2
    • Insert the plastic opening tool in the groove at the top of the phone.
    • Rotate the tool to create an opening between the logic board cover and case.
  7. Motorola C290 Logic Board Replacement: 步骤 7 中的图像 1,2 Motorola C290 Logic Board Replacement: 步骤 7 中的图像 2,2
    • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
    • Remove logic board cover and set aside.
  8. Motorola C290 Logic Board Replacement: 步骤 8 中的图像 1,1
    • Use the Spudger to detach the screen wire from the logic board.
  9. Motorola C290 Logic Board Replacement: 步骤 9 中的图像 1,3 Motorola C290 Logic Board Replacement: 步骤 9 中的图像 2,3 Motorola C290 Logic Board Replacement: 步骤 9 中的图像 3,3
    • Insert the Spudger into the slot on the top of the logic board.
    • Gently pry to loosen the top of the logic board.
    • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
    • Grab the top of the logic board and pull at an angle to remove.
结论
另外一个人完成了本指南。
Paul
于04/15/10注册
22 声望
撰写一个指南
团队
Cal Poly, Team 24-28, Regan Spring 2010 Cal Poly, Team 24-28, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G28
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,388
