当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Position Motorola C290 so that the back of the phone is facing up.
Apply pressure to the back cover while simultaneously sliding it downwards.
Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
Place your finger in the notch at the top of the battery.
Gently lift and pull out battery.
Unscrew antenna head from top of phone by twisting counterclockwise.
Pull the antenna out through the top hole and set aside.
Remove the plastic tube by lifting the bottom and pulling out towards yourself.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与6其他贡献者
于04/15/10注册
79 声望
创作了4篇指南
徽章: 6
+ 3更多徽章
CPSU-REGAN-S10S24G28
4 名成员
创作了6篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 11
总计 1,989
