跳转到主内容
Motorola C261 Front Speaker Replacement
你所需要的
  1. Motorola C261 Front Speaker Replacement, Place Phone: 步骤 1 中的图像 1,1
    • Place the phone with the screen facedown on a flat surface.
  2. Motorola C261 Front Speaker Replacement, Latch and Back Cover: 步骤 2 中的图像 1,2 Motorola C261 Front Speaker Replacement, Latch and Back Cover: 步骤 2 中的图像 2,2
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
  3. Motorola C261 Front Speaker Replacement, Remove Battery: 步骤 3 中的图像 1,2 Motorola C261 Front Speaker Replacement, Remove Battery: 步骤 3 中的图像 2,2
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
  4. Motorola C261 Front Speaker Replacement, Clips: 步骤 4 中的图像 1,2 Motorola C261 Front Speaker Replacement, Clips: 步骤 4 中的图像 2,2
    • Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
  5. Motorola C261 Front Speaker Replacement, Button Circuit Board: 步骤 5 中的图像 1,2 Motorola C261 Front Speaker Replacement, Button Circuit Board: 步骤 5 中的图像 2,2
    • The circuit board for the buttons is now free to be removed and replaced.
  6. Motorola C261 Front Speaker Replacement, Front Speaker: 步骤 6 中的图像 1,2 Motorola C261 Front Speaker Replacement, Front Speaker: 步骤 6 中的图像 2,2
    • Pry under the display screen, around each edge until it comes loose from the circuit board.
    • You are removing the black plastic piece that holds the button circuit board. The piece has an aluminum frame around it. The two pieces will be removed together and don't need to be separated.
  7. Motorola C261 Front Speaker Replacement, Lifting Framework: 步骤 7 中的图像 1,1
    • Gently remove the plastic and metal framework of the phone by picking it up.
  8. Motorola C261 Front Speaker Replacement: 步骤 8 中的图像 1,2 Motorola C261 Front Speaker Replacement: 步骤 8 中的图像 2,2
    • The front speaker should be contained in the framework that you just removed. Remove the speaker by lifting it out.
    • Use a tool that isn't sharp to poke it out should the first method prove too difficult.
结论
Jason
于10/23/14注册
305 声望
创作了3篇指南
团队
Michigan Tech, Team 1-6, Lauer Fall 2014 Michigan Tech, Team 1-6, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 116
