跳转到主内容
Motorola C261 Front Housing Replacement
你所需要的
  1. Motorola C261 Front Housing Replacement, Place Phone: 步骤 1 中的图像 1,1
    • Place the phone with the screen facedown on a flat surface.
  2. Motorola C261 Front Housing Replacement, Latch and Back Cover: 步骤 2 中的图像 1,2 Motorola C261 Front Housing Replacement, Latch and Back Cover: 步骤 2 中的图像 2,2
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
  3. Motorola C261 Front Housing Replacement, Remove Battery: 步骤 3 中的图像 1,2 Motorola C261 Front Housing Replacement, Remove Battery: 步骤 3 中的图像 2,2
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
  4. Motorola C261 Front Housing Replacement, Screws in Rear Housing: 步骤 4 中的图像 1,1
    • Remove the four 8.5 mm screws from under the battery cover with a T4 Torx screwdriver.
    • Remove the two 8.5 mm screws from the top of the phone with a T4 Torx screwdriver.
  5. Motorola C261 Front Housing Replacement, Rear Housing: 步骤 5 中的图像 1,2 Motorola C261 Front Housing Replacement, Rear Housing: 步骤 5 中的图像 2,2
    • Using the plastic pry tool remove the rear housing from the rest of the phone. You may have to pry around all edges of the phone, not just the edge shown.
    • When you remove the rear housing, the rubber cover for the headphone jack/charge port may fall out. If not, remove it.
  6. Motorola C261 Front Housing Replacement, Spacers: 步骤 6 中的图像 1,2 Motorola C261 Front Housing Replacement, Spacers: 步骤 6 中的图像 2,2
    • Remove the small black circular rubber spacer.
    • Remove the white rubber spacer.
    • These pieces are small and easy to lose, especially the black one. Set them somewhere safe!
  7. Motorola C261 Front Housing Replacement, Motherboard and Front Housing: 步骤 7 中的图像 1,2 Motorola C261 Front Housing Replacement, Motherboard and Front Housing: 步骤 7 中的图像 2,2
    • Gently remove the motherboard assembly from the front housing.
    • Now, the front housing is free to be replaced, as well as the cosmetic keypad.
结论
Helen Karsten
于10/23/14注册
209 声望
创作了2篇指南
团队
Michigan Tech, Team 1-6, Lauer Fall 2014 Michigan Tech, Team 1-6, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 127
