跳转到主内容
Motorola C168 Screen Replacement
你所需要的
  1. Motorola C168 Screen Replacement, Battery: 步骤 1 中的图像 1,2 Motorola C168 Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Screen Replacement: 步骤 2 中的图像 1,2 Motorola C168 Screen Replacement: 步骤 2 中的图像 2,2
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Screen Replacement, SIM Card: 步骤 3 中的图像 1,2 Motorola C168 Screen Replacement, SIM Card: 步骤 3 中的图像 2,2
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Screen Replacement, Front Panel: 步骤 4 中的图像 1,2 Motorola C168 Screen Replacement, Front Panel: 步骤 4 中的图像 2,2
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Screen Replacement: 步骤 5 中的图像 1,2 Motorola C168 Screen Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $3.99
    购买
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
  6. Motorola C168 Screen Replacement, Screen: 步骤 6 中的图像 1,2 Motorola C168 Screen Replacement, Screen: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $3.99
    购买
    • Place the phone on its back.
    • Insert the spudger at the bottom of the phone, between the phone's frame and the circuit board.
    • Remove the circuit board from the frame.
    • Removing the board takes more force than you would expect.
  7. Motorola C168 Screen Replacement: 步骤 7 中的图像 1,2 Motorola C168 Screen Replacement: 步骤 7 中的图像 2,2
    • Bend the screen clamps outward so they are no longer underneath the circuit board.
    • Pull the screen encasing away from the circuit board.
    • Caution: The screen-to-phone interface will still be connected.
  8. Motorola C168 Screen Replacement: 步骤 8 中的图像 1,2 Motorola C168 Screen Replacement: 步骤 8 中的图像 2,2
    • Unplug the screen-to-phone interface.
    • Remove the screen from its encasing by pushing it out.
结论
另外一个人完成了本指南。
Christopher Wu
于04/17/12注册
37 声望
创作了3篇指南
团队
Cal Poly, Team 12-40, Regan Spring 2012 Cal Poly, Team 12-40, Regan Spring 2012 的会员
CPSU-REGAN-S12S12G40
4 名成员
创作了8篇指南
2条评论
motorola c168 network not working problem. how to repair network problem?
sattar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,363
