1. Begin by flipping your phone over so that the back cover is facing up. Apply force to the back cover and simultaneously slide the cover down. Note: Applying pressure on the ridges will make it easier to remove the cover.
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
  2. Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery. Lift and remove the battery. Lift and remove the battery.
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
  3. Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water. Gently slide the SIM card out and lift to remove it from the phone. Gently slide the SIM card out and lift to remove it from the phone.
    • Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water.
    • Gently slide the SIM card out and lift to remove it from the phone.
  4. Use a Torx T-5 screwdriver to remove the screws on the back of the phone. The screws are 6.86 mm long and 1.61mm in diameter. The screws are 6.86 mm long and 1.61mm in diameter.
    • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
    • The screws are 6.86 mm long and 1.61mm in diameter.
  5. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  6. Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone. Repeat for the other side Repeat for the other side
    • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
    • Repeat for the other side
  7. Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top. Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together. Release a total of six hooks from the sides and top to free the phone into two halves.
    • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
      • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
    • Release a total of six hooks from the sides and top to free the phone into two halves.
  8. Using a Torx T-5 screwdriver remove the screws at the top of the phone. The screws are 6.86 mm long and 1.61mm in diameter. The screws are 6.86 mm long and 1.61mm in diameter.
    • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
  9. Use plastic pry tools to free the circuit board from the case There are two hooks (one on each side) holding the circuit board into the case. Then grip the circuit board and lift to remove the circuit board from the case
    • Use plastic pry tools to free the circuit board from the case
      • There are two hooks (one on each side) holding the circuit board into the case.
    • Then grip the circuit board and lift to remove the circuit board from the case
  10. Unhook the antenna by releasing the two hooks, one on each side of the phone. Detach the antenna from the back of the circuit board This small black rubber cover may detach.
    • Unhook the antenna by releasing the two hooks, one on each side of the phone.
    • Detach the antenna from the back of the circuit board
    • This small black rubber cover may detach.
  11. Unhook the 10 clips holding the metal screen cover in place and pull up to detach it from the logic board. There are four clips at the top, two along each side, and two clips at the bottom of the metal cover. There are four clips at the top, two along each side, and two clips at the bottom of the metal cover.
    • Unhook the 10 clips holding the metal screen cover in place and pull up to detach it from the logic board.
      • There are four clips at the top, two along each side, and two clips at the bottom of the metal cover.
  12. Lift to remove the speaker from its contact point on the logic board. Lift to remove the speaker from its contact point on the logic board.
    • Lift to remove the speaker from its contact point on the logic board.
结论
Kyle Olbrich
于2012年03月09日注册
27 信誉积分
创作了4篇指南
团队
Clemson, Team 2-2, Benson Spring 2012 Clemson, Team 2-2, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G2
3 名成员
创作了15篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 848
