跳转到主内容
Motorola Atrix HD Rear Chassis Disassembly
你所需要的
  1. Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: 步骤 1 中的图像 1,3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: 步骤 1 中的图像 2,3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: 步骤 1 中的图像 3,3
    • Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
    • The adhesive strips may stay on the back cover or the battery.
  2. Motorola Atrix HD Rear Chassis Disassembly: 步骤 2 中的图像 1,2 Motorola Atrix HD Rear Chassis Disassembly: 步骤 2 中的图像 2,2
    • The back case portion may be removed after the battery has been removed.
    • Use the T5 Torx screwdriver to remove the 10 coarse-thread 5mm screws
  3. Motorola Atrix HD Rear Chassis Disassembly: 步骤 3 中的图像 1,3 Motorola Atrix HD Rear Chassis Disassembly: 步骤 3 中的图像 2,3 Motorola Atrix HD Rear Chassis Disassembly: 步骤 3 中的图像 3,3
    • Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
    • Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
    • The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
结论
2等其他人完成本指南。
Gabriel Agaman
于10/28/15注册
597 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-8, Miles Fall 2015 UMass Dartmouth, Team 1-8, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G8
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 251
