跳转到主内容
Motorola Atrix 4G LCD Replacement
你所需要的
  1. Motorola Atrix 4G LCD Replacement, Battery: 步骤 1 中的图像 1,1
    • Pry the rear cover from the back of the phone.
  2. Motorola Atrix 4G LCD Replacement: 步骤 2 中的图像 1,2 Motorola Atrix 4G LCD Replacement: 步骤 2 中的图像 2,2
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G LCD Replacement, Antenna: 步骤 3 中的图像 1,3 Motorola Atrix 4G LCD Replacement, Antenna: 步骤 3 中的图像 2,3 Motorola Atrix 4G LCD Replacement, Antenna: 步骤 3 中的图像 3,3
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
  4. Motorola Atrix 4G LCD Replacement: 步骤 4 中的图像 1,2 Motorola Atrix 4G LCD Replacement: 步骤 4 中的图像 2,2
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
  5. Motorola Atrix 4G LCD Replacement: 步骤 5 中的图像 1,2 Motorola Atrix 4G LCD Replacement: 步骤 5 中的图像 2,2
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G LCD Replacement: 步骤 6 中的图像 1,1
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G LCD Replacement: 步骤 7 中的图像 1,1
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  8. Motorola Atrix 4G LCD Replacement: 步骤 8 中的图像 1,1
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
  9. Motorola Atrix 4G LCD Replacement, Motherboard: 步骤 9 中的图像 1,2 Motorola Atrix 4G LCD Replacement, Motherboard: 步骤 9 中的图像 2,2
    • To remove the motherboard, first dislodge the right side of the motherboard, where the external connections are located, from the rest of the phone.
    • This can be done by placing a spudger in between the two ports on the phone, between the black plastic and motherboard, and prying out.
    • The motherboard should be able to be easily lifted upwards after dislodging it.
    • If the white rubber piece moves, replace it where it came from upon reassembly.
  10. Motorola Atrix 4G LCD Replacement: 步骤 10 中的图像 1,2 Motorola Atrix 4G LCD Replacement: 步骤 10 中的图像 2,2
    • First, several connections must be disconnected to completely separate the motherboard from the rest of the phone.
    • The connection highlighted with a red box must be pulled down instead of out.
    • Using the spudger tool, separate the two connections on the motherboard highlighted with orange circles by pulling them out.
    • The black switch on top of this connection acts as a lock. Push it forwards to unlock the connection.
  11. Motorola Atrix 4G LCD Replacement: 步骤 11 中的图像 1,1
    • After disconnecting the motherboard, there should be five distinct and separate parts of the phone: back cover, back case, front case, battery, and motherboard.
  12. Motorola Atrix 4G LCD Replacement, Screen: 步骤 12 中的图像 1,1
    • Using a heat gun or a hair dryer on high heat, soften the adhesive securing the glass screen.
    • Direct the hot air along the front edges of the glass until the phone is warm to the touch.
  13. Motorola Atrix 4G LCD Replacement: 步骤 13 中的图像 1,3 Motorola Atrix 4G LCD Replacement: 步骤 13 中的图像 2,3 Motorola Atrix 4G LCD Replacement: 步骤 13 中的图像 3,3
    • Using a plastic opening tool, carefully pry up the bottom of the display glass.
    • Slowly work your way around the phone, using the plastic opening tool to separate the glass from the phone.
    • As you work, the adhesive may cool and harden. You may need to heat up the glass again as you work your way around the screen.
  14. Motorola Atrix 4G LCD Replacement: 步骤 14 中的图像 1,2 Motorola Atrix 4G LCD Replacement: 步骤 14 中的图像 2,2
    • Using a spudger, lift up the digitizer cable that is attached to the glass.
    • Be careful not to damage the cable. It is glued in place and hard to remove.
  15. Motorola Atrix 4G LCD Replacement: 步骤 15 中的图像 1,3 Motorola Atrix 4G LCD Replacement: 步骤 15 中的图像 2,3 Motorola Atrix 4G LCD Replacement: 步骤 15 中的图像 3,3
    • Now that the cable has been removed you can slide it through the opening and detach the glass.
    • Be careful as you pull the cable through the opening. The cable is easily damaged.
    • Once the cable is pushed through the slot, the glass can be fully removed.
  16. Motorola Atrix 4G LCD Replacement, LCD: 步骤 16 中的图像 1,3 Motorola Atrix 4G LCD Replacement, LCD: 步骤 16 中的图像 2,3 Motorola Atrix 4G LCD Replacement, LCD: 步骤 16 中的图像 3,3
    • With the glass removed you can now access the LCD screen.
    • Using a plastic opening tool, slide it in between LCD screen and the case of the phone and then pry it out carefully.
    • Slide the case opener tool along the side until the LCD pops out of the case.
    • Carefully guide the cables attached to the back of the LCD through the hole.
  17. Motorola Atrix 4G LCD Replacement: 步骤 17 中的图像 1,1
    • The LCD is now ready to be replaced.
结论
4等其他人完成本指南。
Paul Sullivan
于04/19/12注册
238 声望
撰写一个指南
团队
Cal Poly, Team 9-42, Regan Spring 2012 Cal Poly, Team 9-42, Regan Spring 2012 的会员
CPSU-REGAN-S12S9G42
6 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 21
总计 6,935
