跳转到主内容
Motorola Atrix 4G Antenna Replacement
你所需要的
  1. Motorola Atrix 4G Antenna Replacement, Battery: 步骤 1 中的图像 1,1
    • Pry the rear cover from the back of the phone.
  2. Motorola Atrix 4G Antenna Replacement: 步骤 2 中的图像 1,2 Motorola Atrix 4G Antenna Replacement: 步骤 2 中的图像 2,2
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Antenna Replacement, Antenna: 步骤 3 中的图像 1,3 Motorola Atrix 4G Antenna Replacement, Antenna: 步骤 3 中的图像 2,3 Motorola Atrix 4G Antenna Replacement, Antenna: 步骤 3 中的图像 3,3
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
  4. Motorola Atrix 4G Antenna Replacement: 步骤 4 中的图像 1,2 Motorola Atrix 4G Antenna Replacement: 步骤 4 中的图像 2,2
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
  5. Motorola Atrix 4G Antenna Replacement: 步骤 5 中的图像 1,2 Motorola Atrix 4G Antenna Replacement: 步骤 5 中的图像 2,2
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G Antenna Replacement: 步骤 6 中的图像 1,1
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G Antenna Replacement: 步骤 7 中的图像 1,1
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  8. Motorola Atrix 4G Antenna Replacement: 步骤 8 中的图像 1,1
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
结论
5等其他人完成本指南。
Derek Walker
于04/19/12注册
297 声望
创作了4篇指南
团队
Cal Poly, Team 9-42, Regan Spring 2012 Cal Poly, Team 9-42, Regan Spring 2012 的会员
CPSU-REGAN-S12S9G42
6 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 5,450
