简介
This process involves first removing the battery and outer case. After, the motherboard can be easily removed.
你所需要的
Hold the phone and pull the back latch down towards the bottom.
Remove the back panel by releasing the latch and lifting from the top.
Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
Once the screws are removed, simply lift the back panel off
即将完成!
结论
另外一个人完成了本指南。
