跳转到主内容
加入维修社区 - 创建账户
Moto X Pure Edition Front Camera Replacement
浏览量: 1826
浏览统计数据:
过去24小时
2
过去 7 天:
17
过去 30 天:
94
总计
1,826
评论: 23
23 comments on steps.
已完成: 0
暂时还没有人将本指南标记为“已完成”。你会是第一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 没有估计
难度: 中等
更好的介绍
通过完成或修改其开头介绍以改善本指南。
Follow this guide to replace the front camera in your Moto X Pure Edition.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
你所需要的
配件
工具
    1. Moto X Pure Edition Front Camera Replacement, Opening Procedure: 步骤 1 中的图像 1,1
      • Prepare an iOpener and heat the back of the phone along its right edge for about five minutes. This will help soften the adhesive securing the back cover.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the LCD display and internal battery are both susceptible to heat damage.
      询问修复机器人
      添加评论
    2. Moto X Pure Edition Front Camera Replacement: 步骤 2 中的图像 1,3 Moto X Pure Edition Front Camera Replacement: 步骤 2 中的图像 2,3 Moto X Pure Edition Front Camera Replacement: 步骤 2 中的图像 3,3
      • In the following steps, you'll be cutting through the adhesive securing the back cover.
      • The adhesive is laid out as seen in the first image, which shows the inside of the cover.
      • Avoid slicing in this area to avoid damaging delicate ribbon cables.
      询问修复机器人
      添加评论
    3. Moto X Pure Edition Front Camera Replacement: 步骤 3 中的图像 1,3 Moto X Pure Edition Front Camera Replacement: 步骤 3 中的图像 2,3 Moto X Pure Edition Front Camera Replacement: 步骤 3 中的图像 3,3
      在这个步骤中使用的工具:
      • Hold a pair of pointed tweezers closed, and insert them into the small hole on the edge of the back cover near the SIM card slot.
      • Use the tweezers to lift the cover up slightly, and slide an opening pick into the gap between the cover and the frame.
      添加评论
    4. Moto X Pure Edition Front Camera Replacement: 步骤 4 中的图像 1,3 Moto X Pure Edition Front Camera Replacement: 步骤 4 中的图像 2,3 Moto X Pure Edition Front Camera Replacement: 步骤 4 中的图像 3,3
      • Slide the opening pick along the edge of the phone to slice through the back cover adhesive.
      • Try to insert the pick as far as you can underneath the cover, toward the center of the cover. There's thick adhesive on the middle of the cover that must be separated.
      • Leave the pick in place as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
      添加评论
    5. Moto X Pure Edition Front Camera Replacement: 步骤 5 中的图像 1,1
      • Prepare an iOpener and heat the back of the phone along its left edge for about five minutes. This will help soften the adhesive securing the rest of the back cover.
      询问修复机器人
      添加评论
    6. Moto X Pure Edition Front Camera Replacement: 步骤 6 中的图像 1,2 Moto X Pure Edition Front Camera Replacement: 步骤 6 中的图像 2,2
      • Slice through the adhesive along the bottom edge of the phone.
      • Re-heat the back cover as needed to prevent the glue from cooling and hardening.
      询问修复机器人
      添加评论
    7. Moto X Pure Edition Front Camera Replacement: 步骤 7 中的图像 1,2 Moto X Pure Edition Front Camera Replacement: 步骤 7 中的图像 2,2
      • Slice through the adhesive along the left side of the phone.
      • Stop cutting when you get to the edge of the volume buttons. Cutting past this point may damage the ribbon cables underneath the cover.
      询问修复机器人
      添加评论
    8. Moto X Pure Edition Front Camera Replacement: 步骤 8 中的图像 1,3 Moto X Pure Edition Front Camera Replacement: 步骤 8 中的图像 2,3 Moto X Pure Edition Front Camera Replacement: 步骤 8 中的图像 3,3
      • Slice through the adhesive along the top edge of the phone, pulling the pick out slightly to guide it around the rear-facing camera.
      询问修复机器人
      添加评论
    9. Moto X Pure Edition Front Camera Replacement: 步骤 9 中的图像 1,3 Moto X Pure Edition Front Camera Replacement: 步骤 9 中的图像 2,3 Moto X Pure Edition Front Camera Replacement: 步骤 9 中的图像 3,3
      在这个步骤中使用的工具:
      Tesa 61395 Tape
      $8.95
      • Carefully pry the cover away from the phone.
      • This may take a lot of force if the adhesive in the middle is still attached. As you lift the cover, you may need to use an opening pick to slice through any remaining adhesive.
      • To reinstall the back cover:
      • First use tweezers and a spudger to peel and scrape away any remaining adhesive from both the back cover and the phone's chassis.
      • Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
      • Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Before installing the precut adhesive on the back cover, remove the metal insert. Install the adhesive, then replace the insert.
      • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
      • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
      添加评论
    10. Moto X Pure Edition Front Camera Replacement: 步骤 10 中的图像 1,3 Moto X Pure Edition Front Camera Replacement: 步骤 10 中的图像 2,3 Moto X Pure Edition Front Camera Replacement: 步骤 10 中的图像 3,3
      • Use the point of a spudger to pry up the rubber cover over the battery connector.
      • Remove the rubber cover.
      询问修复机器人
      添加评论
    11. Moto X Pure Edition Front Camera Replacement: 步骤 11 中的图像 1,2 Moto X Pure Edition Front Camera Replacement: 步骤 11 中的图像 2,2
      • Use the flat end of a spudger to pry the battery connector straight up and out of its socket.
      • Only pry the small tab on the end of the connector opposite the ribbon cable. Do not push against the connector too hard or you risk damaging the plug on the motherboard.
      添加评论
    12. Moto X Pure Edition Front Camera Replacement: 步骤 12 中的图像 1,2 Moto X Pure Edition Front Camera Replacement: 步骤 12 中的图像 2,2
      • Use tweezers to lift away the rubber cover over the flash connector.
      询问修复机器人
      添加评论
    13. Moto X Pure Edition Front Camera Replacement: 步骤 13 中的图像 1,2 Moto X Pure Edition Front Camera Replacement: 步骤 13 中的图像 2,2
      • Use the tip of a spudger against the corner of the flash connector to pry the connecter straight up and out of its socket.
      询问修复机器人
      添加评论
    14. Moto X Pure Edition Front Camera Replacement: 步骤 14 中的图像 1,1
      • Use a T3 Torx driver to remove twenty 2.4 mm screws.
      添加评论
    15. Moto X Pure Edition Front Camera Replacement: 步骤 15 中的图像 1,2 Moto X Pure Edition Front Camera Replacement: 步骤 15 中的图像 2,2
      • Use the point of a spudger to push the small clip securing the left side of the midframe toward the edge of the phone, releasing the clip.
      添加评论
    16. Moto X Pure Edition Front Camera Replacement: 步骤 16 中的图像 1,1
      • Repeat the previous step to release the right side midframe clip.
      询问修复机器人
      添加评论
    17. Moto X Pure Edition Front Camera Replacement: 步骤 17 中的图像 1,3 Moto X Pure Edition Front Camera Replacement: 步骤 17 中的图像 2,3 Moto X Pure Edition Front Camera Replacement: 步骤 17 中的图像 3,3
      • Holding the display by the edges, gently lift the midframe away from the display.
      • Remove the midframe from the display.
      添加评论
    1. Moto X Pure Edition Front Camera Replacement, Front Camera: 步骤 18 中的图像 1,2 Moto X Pure Edition Front Camera Replacement, Front Camera: 步骤 18 中的图像 2,2
      • Use the flat end of the nylon spudger to gently pry up on the front camera connector.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 5-2, Landers Spring 2016 UMass Dartmouth, Team 5-2, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G2
3 名成员
创作了72篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 94
总计 1,826
