跳转到主内容
Moto G4 Vibration Motor Replacement
你所需要的
  1. Moto G4 Vibration Motor Replacement, Back Cover: 步骤 1 中的图像 1,3 Moto G4 Vibration Motor Replacement, Back Cover: 步骤 1 中的图像 2,3 Moto G4 Vibration Motor Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Moto G4 Vibration Motor Replacement: 步骤 2 中的图像 1,2 Moto G4 Vibration Motor Replacement: 步骤 2 中的图像 2,2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Moto G4 Vibration Motor Replacement: 步骤 3 中的图像 1,3 Moto G4 Vibration Motor Replacement: 步骤 3 中的图像 2,3 Moto G4 Vibration Motor Replacement: 步骤 3 中的图像 3,3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Moto G4 Vibration Motor Replacement: 步骤 4 中的图像 1,2 Moto G4 Vibration Motor Replacement: 步骤 4 中的图像 2,2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Moto G4 Vibration Motor Replacement, Midframe: 步骤 5 中的图像 1,3 Moto G4 Vibration Motor Replacement, Midframe: 步骤 5 中的图像 2,3 Moto G4 Vibration Motor Replacement, Midframe: 步骤 5 中的图像 3,3
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Moto G4 Vibration Motor Replacement: 步骤 6 中的图像 1,2 Moto G4 Vibration Motor Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Moto G4 Vibration Motor Replacement: 步骤 7 中的图像 1,1
    • Remove the rubber cover.
  8. Moto G4 Vibration Motor Replacement: 步骤 8 中的图像 1,2 Moto G4 Vibration Motor Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Moto G4 Vibration Motor Replacement: 步骤 9 中的图像 1,1
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  10. Moto G4 Vibration Motor Replacement: 步骤 10 中的图像 1,1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Moto G4 Vibration Motor Replacement: 步骤 11 中的图像 1,1
    • Remove the midframe.
  12. Moto G4 Vibration Motor Replacement, Battery Disconnection: 步骤 12 中的图像 1,2 Moto G4 Vibration Motor Replacement, Battery Disconnection: 步骤 12 中的图像 2,2
    • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
    • Gently pry straight up to disconnect the battery.
    • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
    • During reassembly, align the connector in its socket and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
  13. Moto G4 Vibration Motor Replacement, Vibration Motor: 步骤 13 中的图像 1,2 Moto G4 Vibration Motor Replacement, Vibration Motor: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Pull black flap on bottom of motherboard back.
    • Use tweezers to pop vibration motor off of motherboard.
结论
另外一个人完成了本指南。
Nathan Granger
于02/12/18注册
202 声望
创作了2篇指南
团队
USF Tampa, Team S15-G3, Boczar Spring 2018 USF Tampa, Team S15-G3, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 662
