跳转到主内容
简介
Prerequisite-only guide for removing the midframe from the Moto G4, in order to access internal components for servicing.
配件
没有特定配件。
  1. Moto G4 Midframe Replacement, Back Cover: 步骤 1 中的图像 1,3 Moto G4 Midframe Replacement, Back Cover: 步骤 1 中的图像 2,3 Moto G4 Midframe Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Moto G4 Midframe Replacement: 步骤 2 中的图像 1,2 Moto G4 Midframe Replacement: 步骤 2 中的图像 2,2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Moto G4 Midframe Replacement: 步骤 3 中的图像 1,3 Moto G4 Midframe Replacement: 步骤 3 中的图像 2,3 Moto G4 Midframe Replacement: 步骤 3 中的图像 3,3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Moto G4 Midframe Replacement: 步骤 4 中的图像 1,2 Moto G4 Midframe Replacement: 步骤 4 中的图像 2,2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Moto G4 Midframe Replacement, Midframe: 步骤 5 中的图像 1,3 Moto G4 Midframe Replacement, Midframe: 步骤 5 中的图像 2,3 Moto G4 Midframe Replacement, Midframe: 步骤 5 中的图像 3,3
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Moto G4 Midframe Replacement: 步骤 6 中的图像 1,2 Moto G4 Midframe Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Moto G4 Midframe Replacement: 步骤 7 中的图像 1,1
    • Remove the rubber cover.
  8. Moto G4 Midframe Replacement: 步骤 8 中的图像 1,2 Moto G4 Midframe Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Moto G4 Midframe Replacement: 步骤 9 中的图像 1,1
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  10. Moto G4 Midframe Replacement: 步骤 10 中的图像 1,1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Moto G4 Midframe Replacement: 步骤 11 中的图像 1,1
    • Remove the midframe.
结论
Jeff Suovanen
于2013年08月06日注册
396,640 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Community
146 名成员
创作了16,116篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 64
