跳转到主内容
Moto E5 Plus Battery Replacement
你所需要的
  1. Moto E5 Plus Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • The back and frame of this phone is made of plastic. Be careful when heating the phone.
    • Apply heat, then use a suction cup to lift the back enough to fit an opening pick underneath.
    • Proceed to separate the adhesive around the edges of the phone, reapplying heat as needed.
  2. Moto E5 Plus Battery Replacement: 步骤 2 中的图像 1,1
    • The back of the phone is still attached via the fingerprint sensor's ribbon cable.
    • Gently pull the back of the phone towards the charging port to reveal the shielding plate.
    • Remove the screws and the metal plate.
    • Disconnect the fingerprint sensor cable using a Halberd spudger or opening pick and remove the back of the phone.
  3. Moto E5 Plus Battery Replacement: 步骤 3 中的图像 1,2 Moto E5 Plus Battery Replacement: 步骤 3 中的图像 2,2
    • Remove 15 #00 Philips screws.
    • Insert the pointed end of a spudger underneath the plastic midframe on either side of the battery and pry upwards to disengage the clips.
    • Remove the midframe.
  4. Moto E5 Plus Battery Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery.
    • Remove the battery. The battery has adhesive on each side.
    • Use small amounts of isopropyl alcohol to soften the adhesive if you are having difficulty removing the battery.
结论
4等其他人完成本指南。
Patrick
于05/14/14注册
6,574 声望
创作了21篇指南
5条评论
I was surfing YouTube,I bumped into strange parts (lovethesite) he recommended ifixit.com, now I would like to replace my battery and volume buttons,on my Motorola e5plus,can that be done within fixit parts? how much? Shipping to USA 95401. Thank you.
Gungor Oseguera - 回复
I used your procedure on one Moto E5 Plus but did not discharge the battery to less than 1% and I punctured the bag and toasted my phone. PEOPLE NEED TO FULLY DISCHARGE THE BATTERY!!! I did this procedure on my second phone and was successful! The battery was impossible to get out without deforming the battery package. I pried and pried and pried and finally, pulled the battery from the adhesive.
There are lots of battery discharge apps that allow you to discharge rapidly. It is very difficult to not puncture the battery package. So be sure it is fully discharged before you do this procedure!
Gary Mitchell - 回复
For best safety the phone battery needs to only be under 25%. The phone will say 0% and shut off, but the battery is not fully discharged. Completely discharging lithium ion batteries has the possibility to do serious damage to the chemistry, reducing its lifespan or capacity, or causing it to refuse to charge again.
I've edited the guide to mention this as well, but isopropyl alcohol (ideally high percentage) will soften most phone adhesive, making it significantly easier to remove.
Patrick -
The instructions say apply heat, but the heat gun has two settings. Which setting is best to use, and how far away from the surface, and for how long at a time?
Bruce England - 回复
Use low setting and heat until it's warm. You should be able to touch it comfortably. If the adhesive is still being difficult, alternate between heat and trying to remove
Patrick -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 37
总计 7,730
