跳转到主内容
Motion Computing LE1600 Speaker Modules Replacement
你所需要的
  1. Motion Computing LE1600 Speaker Modules Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device so the screen is facing down.
  2. Motion Computing LE1600 Speaker Modules Replacement: 步骤 2 中的图像 1,2 Motion Computing LE1600 Speaker Modules Replacement: 步骤 2 中的图像 2,2
    • Slide the battery lock switch next to the power slider to the unlocked position.
  3. Motion Computing LE1600 Speaker Modules Replacement: 步骤 3 中的图像 1,3 Motion Computing LE1600 Speaker Modules Replacement: 步骤 3 中的图像 2,3 Motion Computing LE1600 Speaker Modules Replacement: 步骤 3 中的图像 3,3
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
  4. Motion Computing LE1600 Speaker Modules Replacement, Bluetooth Module: 步骤 4 中的图像 1,1
    • Unscrew hard drive panel using a Phillips head #1 screwdriver.
    • (Our device was not given to us with a hard drive or a hard drive panel)
  5. Motion Computing LE1600 Speaker Modules Replacement: 步骤 5 中的图像 1,3 Motion Computing LE1600 Speaker Modules Replacement: 步骤 5 中的图像 2,3 Motion Computing LE1600 Speaker Modules Replacement: 步骤 5 中的图像 3,3
    • Pull clear plastic tab to detach hard drive from tablet.
  6. Motion Computing LE1600 Speaker Modules Replacement: 步骤 6 中的图像 1,2 Motion Computing LE1600 Speaker Modules Replacement: 步骤 6 中的图像 2,2
    • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
  7. Motion Computing LE1600 Speaker Modules Replacement: 步骤 7 中的图像 1,1
    • Pull the brown tabs to disconnect the white ribbon cable on the other side.
  8. Motion Computing LE1600 Speaker Modules Replacement: 步骤 8 中的图像 1,2 Motion Computing LE1600 Speaker Modules Replacement: 步骤 8 中的图像 2,2
    • Caution: do not pull on the wires, instead pull from the plastic connectors.
    • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
  9. Motion Computing LE1600 Speaker Modules Replacement: 步骤 9 中的图像 1,1
    • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
  10. Motion Computing LE1600 Speaker Modules Replacement: 步骤 10 中的图像 1,1
    • Using a spudger, press in the five tabs on the side where the battery was.
    • This should separate the two halves of the device. Carefully set the side with the display off to the side.
  11. Motion Computing LE1600 Speaker Modules Replacement: 步骤 11 中的图像 1,3 Motion Computing LE1600 Speaker Modules Replacement: 步骤 11 中的图像 2,3 Motion Computing LE1600 Speaker Modules Replacement: 步骤 11 中的图像 3,3
    • Locate the Bluetooth board.
    • Disconnect the ribbon cable by pulling on the plastic connector.
  12. Motion Computing LE1600 Speaker Modules Replacement: 步骤 12 中的图像 1,2 Motion Computing LE1600 Speaker Modules Replacement: 步骤 12 中的图像 2,2
    • Unscrew the 4mm screw holding the board onto the tablet.
    • Lift the board out of the tablet and carefully set it aside.
  13. Motion Computing LE1600 Speaker Modules Replacement, Speaker Modules: 步骤 13 中的图像 1,3 Motion Computing LE1600 Speaker Modules Replacement, Speaker Modules: 步骤 13 中的图像 2,3 Motion Computing LE1600 Speaker Modules Replacement, Speaker Modules: 步骤 13 中的图像 3,3
    • Locate speaker connectors on tablet and unplug them by pulling on the plastic heads.
  14. Motion Computing LE1600 Speaker Modules Replacement: 步骤 14 中的图像 1,2 Motion Computing LE1600 Speaker Modules Replacement: 步骤 14 中的图像 2,2
    • To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away.
  15. Motion Computing LE1600 Speaker Modules Replacement: 步骤 15 中的图像 1,2 Motion Computing LE1600 Speaker Modules Replacement: 步骤 15 中的图像 2,2
    • To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet.
  16. Motion Computing LE1600 Speaker Modules Replacement: 步骤 16 中的图像 1,2 Motion Computing LE1600 Speaker Modules Replacement: 步骤 16 中的图像 2,2
    • Unstick the white masking tape and the black electrical tape holding the black and red wire down.
    • Pull out the wire and speaker.
结论
David Troy
于04/04/12注册
44 声望
创作了3篇指南
团队
Cal Poly, Team 15-14, Forte Spring 2012 Cal Poly, Team 15-14, Forte Spring 2012 的会员
CPSU-FORTE-S12S15G14
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,201
