跳转到主内容
Motion Computing LE1600 Battery Replacement
  1. Motion Computing LE1600 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device so the screen is facing down.
  2. Motion Computing LE1600 Battery Replacement: 步骤 2 中的图像 1,2 Motion Computing LE1600 Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the battery lock switch next to the power slider to the unlocked position.
  3. Motion Computing LE1600 Battery Replacement: 步骤 3 中的图像 1,3 Motion Computing LE1600 Battery Replacement: 步骤 3 中的图像 2,3 Motion Computing LE1600 Battery Replacement: 步骤 3 中的图像 3,3
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
结论
David Troy
于04/04/12注册
44 声望
创作了3篇指南
团队
Cal Poly, Team 15-14, Forte Spring 2012 Cal Poly, Team 15-14, Forte Spring 2012 的会员
CPSU-FORTE-S12S15G14
5 名成员
创作了5篇指南
1指南评论
Wow that’s so cool thanks bro
Leon Byrne - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 2,951
