跳转到主内容
Sony SRS-X3 Motherboard Replacement
你所需要的
  1. Sony SRS-X3 Motherboard Replacement, Speakers: 步骤 1 中的图像 1,1
    • Remove the rubber feet on the bottom of the device.
  2. Sony SRS-X3 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the 6 silver screws with a Phillips #1 screwdriver.
    • Remove the bottom plastic cover of speaker.
    Hola este yo tengo un parlante asi pero no kiere gargar
    Chrlz Maza Olivera - 回复
  3. Sony SRS-X3 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws holding the battery pack with the Phillips #1 screwdriver.
    • Remove the battery back with a spudger.
  4. Sony SRS-X3 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the three screws using a Phillips #1 screwdriver.
    • Remove the green circuit board and the battery pack.
    • The battery pack and green circuit board will still be connected to the speaker by a ribbon wire.
  5. Sony SRS-X3 Motherboard Replacement: 步骤 5 中的图像 1,2 Sony SRS-X3 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Pop off the front speaker face (dark grey with little holes) by pushing out 3 tabs where screws were previously located and sticking the spudger in the crack where grey speaker face meets the outer shell.
    • You may really have to pry on this part; it is not easy to remove and will pop out when released.
  6. Sony SRS-X3 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the eight black screws with a Phillips #1 screwdriver.
  7. Sony SRS-X3 Motherboard Replacement: 步骤 7 中的图像 1,2 Sony SRS-X3 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the front face by prying the two black tabs using a spudger.
    • This face is glued in and may need some elbow grease to remove. Don't worry about breaking anything, as it is all connected.
  8. Sony SRS-X3 Motherboard Replacement: 步骤 8 中的图像 1,2 Sony SRS-X3 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the speaker wires from each speaker (2 wires per speaker) and take the speakers out of the device.
    • The speaker wire connectors are made to connect very snug, so they should be hard to remove. Give it a good tug and they should pop off the male end.
    • Remove the speakers from the device.
  9. Sony SRS-X3 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,3 Sony SRS-X3 Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,3 Sony SRS-X3 Motherboard Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Remove the ribbon wire simply by pulling it out of the fixture in which it connects. Once removed, sit the small green board to the side and prepare to remove the Motherboard.
    Can i get a new boad 40 bkb537u cnf2G
    littlereds_10 - 回复
  10. Sony SRS-X3 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Locate the Motherboard through the hole in which the battery pack normally rests.
  11. Sony SRS-X3 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Use your fingers to pull the board upwards while the speakers top is facing downwards. In doing so, use more force than you are comfortable with. (Do NOT worry. The board slides upwards, regardless of the friction that may seem like it is keeping it from sliding out.)
  12. Sony SRS-X3 Motherboard Replacement: 步骤 12 中的图像 1,3 Sony SRS-X3 Motherboard Replacement: 步骤 12 中的图像 2,3 Sony SRS-X3 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Once the Motherboard has been removed, you are free to remove all of the wires that are connected to it. Gently pull on the clips where the wires insert into the board to remove all of the wires.
结论
Zachary Church
于01/17/17注册
101 声望
撰写一个指南
6条评论
hello I want the power board to buy where can I get that to buy
oxco - 回复
Are you still looking for it. I have one. We can negotiate!!
kennycontreras44 -
Do you still have the circuit board 40BKB537U-CNF2G for the Sony SRS X3?
reeree726 - 回复
need a 40BKB537U-CNF2G board, how much shipped to Tucson AZ?
michael ruse - 回复
The charge port (mini usb I think) is broken on sony srs-x3
michael ruse - 回复
I need this part: where can i get
40bkb537u-cnf2g Sony speaker
Dr.Edward Fernandez - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 30
总计 2,854
