简介
If you are having issues with overall suction from the floor brush it may be a belt issue. Overtime the belt can become loose or broken down. Often they need to be replaced after a lot of use. The belt to the Moosoo XL-618A is a small flexible band that helps spin the floor brush. It also connects the brush to the motor, which makes the brush rotate. Here is a guide to replacing it and fixing it.
你所需要的
Remove the eight 11 mm screws on the bottom of the vacuum with the Phillips #1 screwdriver.
即将完成!
结论
