跳转到主内容
Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side)
你所需要的
  1. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side), Back Cover: 步骤 1 中的图像 1,1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 2 中的图像 1,1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 3 中的图像 1,2 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 3 中的图像 2,2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side), Cassette Player (Left Side): 步骤 4 中的图像 1,1
    • Remove the following 6 screws:
    • Four 25 mm Phillips
    • Two 2.5 mm Flathead
  5. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 5 中的图像 1,1
    • Remove the small steel plate on the right-hand side.
  6. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 6 中的图像 1,1
    • Move the brass plate with attached pneumatic cylinder on the left-hand side.
    • Detach the plate at the pneumatic cylinder and leave the plate attached to the torsional spring.
  7. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 7 中的图像 1,3 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 7 中的图像 2,3 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 7 中的图像 3,3
    • Stand the unit up and press eject to open the door on the cassette player.
    • Gripping the cassette player from the back, lift upwards on the door to unclip it from the bar around which it rotates. This may take some effort.
  8. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 8 中的图像 1,1
    • Remove the 5 mm Phillips screw holding the blue and yellow wires in place.
  9. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 9 中的图像 1,3 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 9 中的图像 2,3 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 9 中的图像 3,3
    • Unsolder the red and white wires leading from the cassette player unit.
  10. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 10 中的图像 1,1
    • Unplug the grey wire leading from the cassette player.
  11. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 步骤 11 中的图像 1,1
    • Remove the cassette player.
结论
Dustin Platt
于04/01/15注册
931 声望
创作了6篇指南
团队
Cal Poly, Team 12-5, Lancaster Spring 2015 Cal Poly, Team 12-5, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G5
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 232
