跳转到主内容
Montgomery Ward GEN-39500 Back Cover Replacement
你所需要的
  1. Montgomery Ward GEN-39500 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Back Cover Replacement: 步骤 3 中的图像 1,2 Montgomery Ward GEN-39500 Back Cover Replacement: 步骤 3 中的图像 2,2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
结论
Dustin Platt
于04/01/15注册
931 声望
创作了6篇指南
团队
Cal Poly, Team 12-5, Lancaster Spring 2015 Cal Poly, Team 12-5, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G5
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 106
