跳转到主内容
Monster Soundstage S2 Speaker Grille Replacement
你所需要的
  1. Monster Soundstage S2 Speaker Grille Replacement, Speaker Grille: 步骤 1 中的图像 1,2 Monster Soundstage S2 Speaker Grille Replacement, Speaker Grille: 步骤 1 中的图像 2,2
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Speaker Grille Replacement: 步骤 2 中的图像 1,3 Monster Soundstage S2 Speaker Grille Replacement: 步骤 2 中的图像 2,3 Monster Soundstage S2 Speaker Grille Replacement: 步骤 2 中的图像 3,3
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Speaker Grille Replacement: 步骤 3 中的图像 1,1
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Speaker Grille Replacement: 步骤 4 中的图像 1,3 Monster Soundstage S2 Speaker Grille Replacement: 步骤 4 中的图像 2,3 Monster Soundstage S2 Speaker Grille Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Speaker Grille Replacement: 步骤 5 中的图像 1,2 Monster Soundstage S2 Speaker Grille Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Speaker Grille Replacement: 步骤 6 中的图像 1,2 Monster Soundstage S2 Speaker Grille Replacement: 步骤 6 中的图像 2,2
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Speaker Grille Replacement: 步骤 7 中的图像 1,3 Monster Soundstage S2 Speaker Grille Replacement: 步骤 7 中的图像 2,3 Monster Soundstage S2 Speaker Grille Replacement: 步骤 7 中的图像 3,3
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Speaker Grille Replacement: 步骤 8 中的图像 1,1
    • Remove the front speaker grille.
结论
3等其他人完成本指南。
Shaw Hughes
于01/30/17注册
831 声望
创作了5篇指南
团队
Cal Poly, Team 21-5, Maness Winter 2017 Cal Poly, Team 21-5, Maness Winter 2017 的会员
CPSU-MANESS-W17S21G5
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 429
