跳转到主内容
Monster SoundStage S1 Mini Speaker Replacement
你所需要的
  1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Monster SoundStage S1 Mini Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
  2. Monster SoundStage S1 Mini Speaker Replacement: 步骤 2 中的图像 1,2 Monster SoundStage S1 Mini Speaker Replacement: 步骤 2 中的图像 2,2
    • Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
  3. Monster SoundStage S1 Mini Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the black putty from the speaker wires at both ends of the speaker board.
  4. Monster SoundStage S1 Mini Speaker Replacement: 步骤 4 中的图像 1,3 Monster SoundStage S1 Mini Speaker Replacement: 步骤 4 中的图像 2,3 Monster SoundStage S1 Mini Speaker Replacement: 步骤 4 中的图像 3,3
    • Solder the black plastic encasing the red and black wires.
  5. Monster SoundStage S1 Mini Speaker Replacement: 步骤 5 中的图像 1,2 Monster SoundStage S1 Mini Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove both the black and red wires with pliers
    • Pliers may stick to speaker because it is magnetic.
  6. Monster SoundStage S1 Mini Speaker Replacement: 步骤 6 中的图像 1,2 Monster SoundStage S1 Mini Speaker Replacement: 步骤 6 中的图像 2,2
    • Tuck wires through the hole where the speaker is located, then gently push the speaker out.
    • The 1.2 cm Torx security screws that stayed in place near the speaker will now fall out.
    • To remove the other speaker repeat steps 3-6
结论
另外一个人完成了本指南。
团队
CSU Fullerton, Team 2-6, Bruce Fall 2016 CSU Fullerton, Team 2-6, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G6
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 512
