跳转到主内容
Moen Single Handle Faucet Cartridge (Model: 1225) Replacement
你所需要的
  1. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement, Cartridge: 步骤 1 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement, Cartridge: 步骤 1 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement, Cartridge: 步骤 1 中的图像 3,3
    • Turn off the main water supply by inserting your meter key into the curb stop valve handle and rotating it 180 degrees counterclockwise to the closed position.
    • If you have a gate valve, rotate the valve counterclockwise to the closed position.
  2. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 2 中的图像 1,2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 2 中的图像 2,2
    • Open the faucet handle to relieve water pressure until there is no water flow.
  3. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 3 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 3 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 3 中的图像 3,3
    • Remove the handle cap.
  4. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 4 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 4 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 4 中的图像 3,3
    • Use a Phillips screwdriver to unscrew the connecting handle screw (10-24 x 1-1/8" Button Head Phillips screw).
    • Remove the handle.
  5. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 5 中的图像 1,2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 5 中的图像 2,2
    • Pull out the stop tube.
  6. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 6 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 6 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 6 中的图像 3,3
    • Remove the washer from the brass stem.
  7. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 7 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 7 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 7 中的图像 3,3
    • Using needle-nose pliers, clamp the tip of the notch of the cartridge retaining clip and pull it upwards to remove.
  8. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 8 中的图像 1,2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 8 中的图像 2,2
    • Using a pair of vise grips, clamp firmly onto the brass stem and pull out the old 1225 cartridge.
  9. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 9 中的图像 1,2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 9 中的图像 2,2
    • On the new 1225 cartridge, orient the volume control holes parallel to the floor.
    • Insert the new 1225 cartridge into the valve.
  10. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 10 中的图像 1,2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 10 中的图像 2,2
    • Insert the white twisting cap into the grooves of the new cartridge and push the cartridge into the valve.
    • Remove the white twisting cap.
  11. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 11 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 11 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 11 中的图像 3,3
    • Reinstall the cartridge retainer clip by sliding the clip into the valve.
  12. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 12 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 12 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 12 中的图像 3,3
    • Turn on the main water supply by inserting your meter key into the curb stop valve handle and rotating it 180 degrees clockwise to the open position.
    • If you have a gate valve, rotate the valve clockwise to the open position.
  13. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 13 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 13 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 13 中的图像 3,3
    • Clamp the brass stem with vice grips and rotate it 90 degrees to the left, checking the water temperature for hot water.
    • From this position, rotate the brass stem 180 degrees to the right, checking the water temperature for cold water.
    • If the hot and cold operations are reversed, use vice grips to clamp onto the brass stem and rotate it 180 degrees from the original position.
  14. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 14 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 14 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 14 中的图像 3,3
    • Push the washer onto the brass stem.
  15. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 15 中的图像 1,2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 15 中的图像 2,2
    • Replace the stop tube by pushing it onto the valve.
  16. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 16 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 16 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 16 中的图像 3,3
    • Insert the handle onto the stop tube.
    • Use a Phillips screwdriver to screw in the connecting handle screw (10-24 x 1-1/8" Button Head Phillips screw).
  17. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 17 中的图像 1,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 17 中的图像 2,3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 步骤 17 中的图像 3,3
    • Replace the handle cap.
结论
If your faucet continues to leak after replacing the cartridge, there may be another underlying issue causing the problem with your plumbing. Inspect the O-rings, seals, and other components of the faucet for any damage and consult professional assistance to resolve the issue.
另外一个人完成了本指南。
Faith Larimore
于07/05/23注册
295 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 119
总计 951
