跳转到主内容
Moen Posi-Temp Cartridge Part #1112b Replacement
你所需要的
  1. Moen Posi-Temp Cartridge Part #1112b Replacement, Moen Posi-Temp Cartridge Part #1112b: 步骤 1 中的图像 1,1
    • Turn the water shutoff valve counter-clockwise to the "off" position.
  2. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 2 中的图像 1,1
    • Open both the hot and cold taps of a nearby faucet or shower until the water no longer flows.
  3. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 3 中的图像 1,2 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 3 中的图像 2,2
    • Turn the handle of the shower valve 180 degrees until it is in the "up" or "on" position.
  4. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 4 中的图像 1,2 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 4 中的图像 2,2
    • Unscrew the handle screw with an Allen wrench.
    • Remove the handle.
  5. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 5 中的图像 1,2 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 5 中的图像 2,2
    • Remove the handle adaptor screw with a Phillips screwdriver.
    • Remove the handle adaptor simply by pulling it out.
  6. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 6 中的图像 1,1
    • Pull out the white key/adjustable limit stop.
  7. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 7 中的图像 1,3 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 7 中的图像 2,3 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 7 中的图像 3,3
    • Gently pull out the stop tube.
  8. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 8 中的图像 1,3 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 8 中的图像 2,3 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 8 中的图像 3,3
    • Using the Phillips head screwdriver, remove the two screws located at the top right corner and bottom left corner.
    • Remove the metal plate.
  9. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 9 中的图像 1,3 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 9 中的图像 2,3 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 9 中的图像 3,3
    • Slide the tip of needle-nose pliers under the notch of the retaining clip and pull the clip upwards.
  10. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 10 中的图像 1,3 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 10 中的图像 2,3 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 10 中的图像 3,3
    • Clamp firmly onto the brass tube with a pair of vice grips and gently but firmly pull out the cartridge.
  11. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 11 中的图像 1,2 Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 11 中的图像 2,2
    • Insert the new Moen Posi-Temp cartridge.
  12. Moen Posi-Temp Cartridge Part #1112b Replacement: 步骤 12 中的图像 1,1
    • Insert the new cartridge into the valve assembly.
    • Ensure that the H/C symbols are facing up.
    • Ensure that the notch on the brass tube is also facing up.
结论
John Mendoza
于09/17/20注册
205 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 53
总计 1,179
