跳转到主内容
简介
Inspection the Modem & WIFI Cards for the Dell Inspiron 9300
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  1. Once the screws are loose, open the panel using a plastic opening tool to access the components below. The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
结论
另外一个人完成了本指南。
Randy McMillan
于2016年09月21日注册
738 信誉积分
创作了4篇指南
团队
Master Techs Master Techs 的会员
Community
300 名成员
创作了1,006篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 78
