跳转到主内容
加入维修社区 - 创建账户
Model O- Mouse Cable Replacement
你所需要的
  1. Model O- Mouse Cable Replacement, Mouse Cable: 步骤 1 中的图像 1,3 Model O- Mouse Cable Replacement, Mouse Cable: 步骤 1 中的图像 2,3 Model O- Mouse Cable Replacement, Mouse Cable: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Turn the mouse over so that the feet are facing you.
    • Remove the bottom two mouse feet using tweezers.
    • If you plan on reusing the mouse feet place them with the adhesive side up.
    添加评论
  2. Model O- Mouse Cable Replacement: 步骤 2 中的图像 1,2 Model O- Mouse Cable Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
    询问修复机器人
    添加评论
  3. Model O- Mouse Cable Replacement: 步骤 3 中的图像 1,3 Model O- Mouse Cable Replacement: 步骤 3 中的图像 2,3 Model O- Mouse Cable Replacement: 步骤 3 中的图像 3,3
    • Slide the base away from the top housing to avoid the front clips.
    • Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
    • Avoid putting strain on the thin LED ribbon cables.
    询问修复机器人
    添加评论
  4. Model O- Mouse Cable Replacement: 步骤 4 中的图像 1,2 Model O- Mouse Cable Replacement: 步骤 4 中的图像 2,2
    • Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
    • Do not pull on the wires.
    • Remove the cable from around the circuit board and from the hole on the front of the mouse.
    询问修复机器人
    添加评论
  5. Model O- Mouse Cable Replacement: 步骤 5 中的图像 1,2 Model O- Mouse Cable Replacement: 步骤 5 中的图像 2,2
    • Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
    • Do not push on the wires.
    添加评论
  6. Model O- Mouse Cable Replacement: 步骤 6 中的图像 1,2 Model O- Mouse Cable Replacement: 步骤 6 中的图像 2,2
    • Route the new cable through the slit in the circuit board.
    • Route the new cable behind the pillars.
    • Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
    • The cable may not stay in place until the top housing is securely fastened back on.
    添加评论
  7. Model O- Mouse Cable Replacement: 步骤 7 中的图像 1,2 Model O- Mouse Cable Replacement: 步骤 7 中的图像 2,2
    • Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
    • Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
    询问修复机器人
    添加评论
  8. Model O- Mouse Cable Replacement: 步骤 8 中的图像 1,1
    • Screw the two screws back in with a Phillips #0 screwdriver.
    • Do not apply too much force or you risk stripping the screw holes.
    询问修复机器人
    添加评论
  9. Model O- Mouse Cable Replacement: 步骤 9 中的图像 1,2 Model O- Mouse Cable Replacement: 步骤 9 中的图像 2,2
    • Reapply the mouse feet with the adhesive side sticking to the mouse.
    • There are plastic ridges to help guide the user where to place the mouse feet.
    • Certain mouse cables come with new mouse feet which can be applied here instead of reapplying the old feet.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
4等其他人完成本指南。
Theo SW
于01/22/21注册
265 声望
撰写一个指南
团队
2指南评论
Where can I get the replacement cable for it?
Ekke Sten - 回复 分享
does glorius them selfs sell replacment parts ?
aniss-97 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 105
总计 14,082
