跳转到主内容
Modal MD-SPBT01 Speaker Wiring Replacement
你所需要的
  1. Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: 步骤 1 中的图像 1,2 Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to pull the metal cover off the top of the speaker.
  2. Modal MD-SPBT01 Speaker Wiring Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws that are inside the holes on the top of the speaker.
    • Use a Phillips 00 screwdriver to remove the 10mm screws.
  3. Modal MD-SPBT01 Speaker Wiring Replacement: 步骤 3 中的图像 1,1
    • Pull the top piece of the speaker off to allow access to the interior.
  4. Modal MD-SPBT01 Speaker Wiring Replacement: 步骤 4 中的图像 1,1
    • Locate the speaker wire connection and remove the wiring.
    • Locate the LED lighting wire and remove that as well.
  5. Modal MD-SPBT01 Speaker Wiring Replacement: 步骤 5 中的图像 1,1
    • Once you disconnect the wires, you can remove the speaker.
  6. Modal MD-SPBT01 Speaker Wiring Replacement: 步骤 6 中的图像 1,2 Modal MD-SPBT01 Speaker Wiring Replacement: 步骤 6 中的图像 2,2
    • Remove the positive and negative connections for the wiring to fully disconnect the wire.
    • Now that you have removed the defective wiring, you can install a new one.
结论
Nathan Hall
于10/13/15注册
258 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 495
