跳转到主内容
Modal MD-SPBT01 LED Light Wiring Replacement
你所需要的
  1. Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: 步骤 1 中的图像 1,2 Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: 步骤 1 中的图像 2,2
    • Use your plastic opening tool to pry the metal speaker cover off.
  2. Modal MD-SPBT01 LED Light Wiring Replacement: 步骤 2 中的图像 1,1
    • You can now use the Phillips #00 screwdriver to remove the four screws.
  3. Modal MD-SPBT01 LED Light Wiring Replacement: 步骤 3 中的图像 1,1
    • With the screws removed, you can now remove the top piece of the speaker to gain access to the interior.
  4. Modal MD-SPBT01 LED Light Wiring Replacement: 步骤 4 中的图像 1,1
    • Locate the LED wire connection and remove it from the mother board.
    • To make replacing the LED wiring easier, remove the speaker wire to fully disconnect the speaker from the mother board.
  5. Modal MD-SPBT01 LED Light Wiring Replacement: 步骤 5 中的图像 1,1
    • Now you can remove the wiring from the speaker side of the device.
    • It might take a bit of work to remove the wires because they are glued down on this side.
  6. Modal MD-SPBT01 LED Light Wiring Replacement: 步骤 6 中的图像 1,1
    • Now with the LED wiring removed, a new wire can be installed.
结论
另外一个人完成了本指南。
Nathan Hall
于10/13/15注册
258 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 627
