跳转到主内容
Mobile Home Skirting Replacement
你所需要的
  1. Mobile Home Skirting Replacement, Mobile Home Skirting: 步骤 1 中的图像 1,3 Mobile Home Skirting Replacement, Mobile Home Skirting: 步骤 1 中的图像 2,3 Mobile Home Skirting Replacement, Mobile Home Skirting: 步骤 1 中的图像 3,3
    • Find the missing pieces or order them from a Mobile Home supply company or Amazon, making sure they are the correct height.
    • Once you have the missing pieces, you can take each piece and start sliding them together as in Image 2.
  2. Mobile Home Skirting Replacement: 步骤 2 中的图像 1,3 Mobile Home Skirting Replacement: 步骤 2 中的图像 2,3 Mobile Home Skirting Replacement: 步骤 2 中的图像 3,3
    • Start by sliding the pieces together (there are what looks like a curved piece on the end of each piece).
    • Once attached to each other, ensure the bottom is slid into the bottom track.
  3. Mobile Home Skirting Replacement: 步骤 3 中的图像 1,3 Mobile Home Skirting Replacement: 步骤 3 中的图像 2,3 Mobile Home Skirting Replacement: 步骤 3 中的图像 3,3
    • Once the panels are secure in the bottom track, you will need to lift the upper track a little.
    • After lifting the upper track upward, you will slide the skirting in under it.
    • After pushing it into the upper track, you will hear a click and it should be secure in the top track.
  4. Mobile Home Skirting Replacement: 步骤 4 中的图像 1,1
    • Once secured in the lower and upper tracks, attach it to the existing panel.
  5. Mobile Home Skirting Replacement: 步骤 5 中的图像 1,1
    • You can secure the panels further by putting screws in the top of the panel if needed. This will help further in case of wind storms.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 35
过去 30 天: 128
总计 1,289
