跳转到主内容
Dismountable Hand Blender
你所需要的
  1. Dismountable Hand Blender, Dismountable Hand Blender: 步骤 1 中的图像 1,1
    • Finding and fixing the problem is a cinch!
    • Disassembling the mixer is very destructive!
    • This appliance is a clear example of planned obsolescence since a worn (carbon) brush makes it fit for the trash.
    • If the fault is in the electronic module, clever cutting can make an acceptable repair possible as shown in this ElectroMax video.
  2. Dismountable Hand Blender: 步骤 2 中的图像 1,3 Dismountable Hand Blender: 步骤 2 中的图像 2,3 Dismountable Hand Blender: 步骤 2 中的图像 3,3
    • The speed control knob is easy to disassemble by inserting a knife blade under the graduated circle and prying it up.
    • There are three obstacles to the removal of the motor and electronics module from this mixer:
    • The entire motor block enclosure is firmly secured with adhesive.
    • This motor bearing fastener acts as a circular mount.
    • This plunger system fastener is a second circular mount.
    • I do not see a way around any of these three issues without a certain amount of "destruction".
  3. Dismountable Hand Blender: 步骤 3 中的图像 1,1
    • One of the two leads has broken off. Possibly made fragile by improper assembly?
    • Correctly resoldering the lead lets the motor operate normally again.
结论
We do need to cut the shell off the mixer, which makes salvaging this part difficult.
4等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Louis Possoz
于01/10/15注册
435 声望
创作了3篇指南
团队
Repair Café Louvain-la-Neuve Repair Café Louvain-la-Neuve 的会员
Repair Café
2 名成员
创作了6篇指南
一条评论
pourquoi acheter du matériel pro si on ne peut pas le réparer
laurencedelanoue - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 58
过去 30 天: 235
总计 14,198
