简介
Accessing the lamp in this television is straightforward and requires minimal disassembly.
  1. Before disassembling your television, be sure it is powered off and unplugged.
    • Before disassembling your television, be sure it is powered off and unplugged.
    • Remove the single 18 mm Phillips #1 screw on the lamp access panel.
  2. Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
    • Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  4. Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
    • Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
      • These two screws are permanently attached to the lamp housing and cannot be removed completely.
  5. Using the handle, pull the lamp housing straight back out of the television.
    • Using the handle, pull the lamp housing straight back out of the television.
      • Do not touch the glass of the lamp with your bare hands. The oil from your fingers can distort the TV image and lead to other issues.
结论
Herman Chai
于2012年10月02日注册
172 信誉积分
创作了3篇指南
团队
Cal Poly, Team 18-39, Regan Fall 2012 Cal Poly, Team 18-39, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G39
4 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 1,878
