跳转到主内容
Mitsubishi WD57734 Back Panel Replacement
你所需要的
  1. Mitsubishi WD57734 Back Panel Replacement, Lamp: 步骤 1 中的图像 1,1
    • Before disassembling your television, be sure it is powered off and unplugged.
    • Remove the single 18 mm Phillips #1 screw on the lamp access panel.
  2. Mitsubishi WD57734 Back Panel Replacement: 步骤 2 中的图像 1,1
    • Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
  3. Mitsubishi WD57734 Back Panel Replacement: 步骤 3 中的图像 1,1
    • Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
    • These two screws are permanently attached to the lamp housing and cannot be removed completely.
  4. Mitsubishi WD57734 Back Panel Replacement: 步骤 4 中的图像 1,1
    • Using the handle, pull the lamp housing straight back out of the television.
    • Do not touch the glass of the lamp with your bare hands. The oil from your fingers can distort the TV image and lead to other issues.
  5. Mitsubishi WD57734 Back Panel Replacement, Back Panel: 步骤 5 中的图像 1,2 Mitsubishi WD57734 Back Panel Replacement, Back Panel: 步骤 5 中的图像 2,2
    • Remove the following 8 Phillips #1 screws:
    • One 22 mm Phillips #1 in the bottom right corner of the back panel.
    • One 18 mm Phillips #1 in the top middle of the back panel.
    • Six 18 mm Phillips #1 in the rest of the back panel.
  6. Mitsubishi WD57734 Back Panel Replacement: 步骤 6 中的图像 1,1
    • Pull the back panel off of the television by gripping the sides and rotating it down.
结论
Herman Chai
于10/02/12注册
196 声望
创作了3篇指南
团队
Cal Poly, Team 18-39, Regan Fall 2012 Cal Poly, Team 18-39, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G39
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,029
