跳转到主内容
Mitsubishi T200 Screen Replacement
你所需要的
  1. Mitsubishi T200 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Mitsubishi T200 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Begin disassembling the phone by removing the phone back cover and battery.
  2. Mitsubishi T200 Screen Replacement: 步骤 2 中的图像 1,1
    • To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
  3. Mitsubishi T200 Screen Replacement: 步骤 3 中的图像 1,1
    • Separate the front plastic component from the motherboard component.
  4. Mitsubishi T200 Screen Replacement: 步骤 4 中的图像 1,1
    • Take the circuit board off the motherboard.
  5. Mitsubishi T200 Screen Replacement: 步骤 5 中的图像 1,2 Mitsubishi T200 Screen Replacement: 步骤 5 中的图像 2,2
    • Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
  6. Mitsubishi T200 Screen Replacement: 步骤 6 中的图像 1,2 Mitsubishi T200 Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
  7. Mitsubishi T200 Screen Replacement: 步骤 7 中的图像 1,2 Mitsubishi T200 Screen Replacement: 步骤 7 中的图像 2,2
    • We can now insert the new screen and reassemble the device.
    • Place the ribbon of the new screen into the clip on the top right of the circuit board.
  8. Mitsubishi T200 Screen Replacement: 步骤 8 中的图像 1,1
    • Clip the new screen onto the circuit board.
  9. Mitsubishi T200 Screen Replacement: 步骤 9 中的图像 1,1
    • Replace circut board back on top of motherboard.
  10. Mitsubishi T200 Screen Replacement: 步骤 10 中的图像 1,1
    • Take the entire internal assembly and join it with the front plastic housing.
    • Ensure that the tops of both pieces clip into place before joining the bottom ones.
  11. Mitsubishi T200 Screen Replacement: 步骤 11 中的图像 1,1
    • Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
    • Snap the whole unit together.
  12. Mitsubishi T200 Screen Replacement: 步骤 12 中的图像 1,1
    • Firmly replace screws into the backing.
终点
2等其他人完成本指南。
Taylor Lewis
于02/13/14注册
14 声望
撰写一个指南
团队
Ohio State, Team 1-5, Meza Spring 2014 Ohio State, Team 1-5, Meza Spring 2014 的会员
OSU-MEZA-S14S1G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 833
