跳转到主内容
Mitsubishi Diamondpoint NXM76LCD Speaker Replacement
你所需要的
  1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: 步骤 1 中的图像 1,3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: 步骤 1 中的图像 2,3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: 步骤 1 中的图像 3,3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the 5 screws: 步骤 2 中的图像 1,1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: 步骤 3 中的图像 1,3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: 步骤 3 中的图像 2,3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: 步骤 3 中的图像 3,3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: 步骤 4 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: 步骤 4 中的图像 2,2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 步骤 5 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: 步骤 6 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: 步骤 6 中的图像 2,2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 步骤 7 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 步骤 7 中的图像 2,2
    • Remove the Phillips #2 screws from the speaker(s).
  8. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 步骤 8 中的图像 1,3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 步骤 8 中的图像 2,3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 步骤 8 中的图像 3,3
    • Pull the speaker off the slots.
结论
另外一个人完成了本指南。
Padraic Hoselton
于08/22/17注册
4,270 声望
创作了12篇指南
团队
Master Techs Master Techs 的会员
Community
327 名成员
创作了1,697篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 124
