跳转到主内容
加入维修社区 - 创建账户
Mitsubishi Diamondpoint NXM76LCD Display Replacement
你所需要的
  1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: 步骤 1 中的图像 1,3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: 步骤 1 中的图像 2,3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: 步骤 1 中的图像 3,3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: 步骤 2 中的图像 1,1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: 步骤 3 中的图像 1,3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: 步骤 3 中的图像 2,3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: 步骤 3 中的图像 3,3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: 步骤 4 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: 步骤 4 中的图像 2,2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: 步骤 5 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: 步骤 5 中的图像 2,2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: 步骤 6 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: 步骤 6 中的图像 2,2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: 步骤 7 中的图像 1,3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: 步骤 7 中的图像 2,3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: 步骤 7 中的图像 3,3
    • Pull the two tabs.
    • Pull the connector off.
  8. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: 步骤 8 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: 步骤 8 中的图像 2,2
    • Remove the switch cable off.
    • Remove the two Phillips #2 screws.
  9. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: 步骤 9 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: 步骤 9 中的图像 2,2
    • Remove the four display power cables.
    • These cables are interchangeable.
  10. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: 步骤 10 中的图像 1,3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: 步骤 10 中的图像 2,3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: 步骤 10 中的图像 3,3
    • Lift the display out.
  11. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: 步骤 11 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: 步骤 11 中的图像 2,2
    • Remove the four Phillips #2 screws.
    • These screws release the display from its enclosure. Hold the screen when removing these screws.
  12. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: 步骤 12 中的图像 1,2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: 步骤 12 中的图像 2,2
    • Remember to plug in all the cables on the display.
结论
2等其他人完成本指南。
Padraic Hoselton
于08/22/17注册
4,366 声望
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 34
总计 379
