跳转到主内容
MistAire Humidifier Cap Spring Replacement
你所需要的
  1. MistAire Humidifier Cap Spring Replacement, Cap Spring: 步骤 1 中的图像 1,2 MistAire Humidifier Cap Spring Replacement, Cap Spring: 步骤 1 中的图像 2,2
    • Lift the blue tank off of the base of the humidifier.
    • The two parts are not attached or snapped together, so they should separate easily.
  2. MistAire Humidifier Cap Spring Replacement: 步骤 2 中的图像 1,3 MistAire Humidifier Cap Spring Replacement: 步骤 2 中的图像 2,3 MistAire Humidifier Cap Spring Replacement: 步骤 2 中的图像 3,3
    • Turn the tank upside down.
    • Turn the round cap counterclockwise to completely unscrew it.
  3. MistAire Humidifier Cap Spring Replacement: 步骤 3 中的图像 1,2 MistAire Humidifier Cap Spring Replacement: 步骤 3 中的图像 2,2
    • There is a white plastic rod that goes through the center of the cap. It has a flat, circular end and a pointed end. The pointed end has a small, blue, silicone ring around it.
    • Push the flat side of the rod until the pointed end protrudes from the other side of the cap.
  4. MistAire Humidifier Cap Spring Replacement: 步骤 4 中的图像 1,3 MistAire Humidifier Cap Spring Replacement: 步骤 4 中的图像 2,3 MistAire Humidifier Cap Spring Replacement: 步骤 4 中的图像 3,3
    • While still pushing on the rod, tug the small, blue, silicone ring completely off of the pointed end.
  5. MistAire Humidifier Cap Spring Replacement: 步骤 5 中的图像 1,2 MistAire Humidifier Cap Spring Replacement: 步骤 5 中的图像 2,2
    • Once the ring is off, pull the rod and spring out from the center of the cap.
  6. MistAire Humidifier Cap Spring Replacement: 步骤 6 中的图像 1,2 MistAire Humidifier Cap Spring Replacement: 步骤 6 中的图像 2,2
    • Slide the broken spring off of the rod.
    • The spring should come off easily.
  7. MistAire Humidifier Cap Spring Replacement: 步骤 7 中的图像 1,2 MistAire Humidifier Cap Spring Replacement: 步骤 7 中的图像 2,2
    • Slide a new 10x6x19mm Tapered Compression Spring around the rod.
    • Ensure the narrower end of the cone-shaped spring goes first.
  8. MistAire Humidifier Cap Spring Replacement: 步骤 8 中的图像 1,2 MistAire Humidifier Cap Spring Replacement: 步骤 8 中的图像 2,2
    • Pinch the spring gently to secure it around the rod.
    • Push the pointed end of the rod all the way through the center hole of the cap. Hold it there for Step 9.
  9. MistAire Humidifier Cap Spring Replacement: 步骤 9 中的图像 1,3 MistAire Humidifier Cap Spring Replacement: 步骤 9 中的图像 2,3 MistAire Humidifier Cap Spring Replacement: 步骤 9 中的图像 3,3
    • Push the small blue ring back onto the pointed end of the rod.
    • You should hear a snap when it’s secured.
  10. MistAire Humidifier Cap Spring Replacement: 步骤 10 中的图像 1,3 MistAire Humidifier Cap Spring Replacement: 步骤 10 中的图像 2,3 MistAire Humidifier Cap Spring Replacement: 步骤 10 中的图像 3,3
    • Now that you have fixed the spring-loaded cap, screw the cap clockwise back onto the bottom of the tank.
  11. MistAire Humidifier Cap Spring Replacement: 步骤 11 中的图像 1,3 MistAire Humidifier Cap Spring Replacement: 步骤 11 中的图像 2,3 MistAire Humidifier Cap Spring Replacement: 步骤 11 中的图像 3,3
    • Place the tank back onto the humidifier base.
    • You have now successfully replaced the spring in the MistAire Humidifier!
终点
Abby
于01/31/24注册
193 声望
撰写一个指南
团队
UC Davis, Team 1-1, Andersen Winter 2024 UC Davis, Team 1-1, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S1G1
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 77
总计 729
