跳转到主内容
Misfit Vapor Battery Replacement
你所需要的
  1. Misfit Vapor Battery Replacement, Watch Strap: 步骤 1 中的图像 1,2 Misfit Vapor Battery Replacement, Watch Strap: 步骤 1 中的图像 2,2
    • Using your fingers, press down on the rubber circles to unbuckle the strap from itself.
    • Once you have removed two of the rubber circles from from a side you will be able to unbuckle the strap on that side.
  2. Misfit Vapor Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • Hold the side power button to ensure the watch is completely shut down.
  3. Misfit Vapor Battery Replacement: 步骤 3 中的图像 1,1
    • To access the battery compartment use the Jaxa-style wrench tool. Secure the midframe while you pop up the back.
    • This will require an extremely high amount of force as there is a rubber seal and the fit is tight.
  4. Misfit Vapor Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the battery cover by carefully using tweezers or the iFixit opening tool.
  5. Misfit Vapor Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the small ribbon cable connector.
    • Remove the battery from the watch.
结论
另外一个人完成了本指南。
Alan Castro
于03/01/23注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 51
总计 576
